vacuum issue or carb issue idk for sure - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 05:09 PM
i just bought a 1979 el camino with a 350 small block. Edelbrock Performer 2101 intake, Edelbrock 1406 carb. runs good. problem is a major hesitation from idle. when i pin it to the floor from an idle it just spits at me then slowly increases rpm. mid range and high range rpm pull. But the low end refuses to work like i want it to. I know i should be able to pin it and smoke the tires in a peel out but it will barely make them chirp. any advice on how exactly to tune this carb or adress this vacuum issue would be greatly appreciated. [IMG]carb[/IMG]
Old 07-10-2011, 05:19 PM
it didnt post pic lol my bad
https://picasaweb.google.com/1026914...67125221185618
https://picasaweb.google.com/1026914...68924437667538
these two pics tell the story of vacuum lines on it the way i got it PLZ HELP
Holley fuel bowl intake vacuum fitting clearance issue. eric32 Engine 7 09-27-2010 06:16 PM
'81 454 vacuum hose issue '81 RV guy Engine 1 06-08-2010 07:57 PM
Carb issue strummin67 Engine 3 08-24-2009 09:21 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 08:17 AM
Carb Issue??? haley72 Engine 2 06-05-2007 09:24 PM
