vacuum or lack of - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2012, 08:46 AM
vacuum or lack of
On my sbc 360 rebuild I have a major issue.My car idles at 1100 rpm until I drop it in gear where it won't idle at all unless I keeps the revs up.I have a 2.8k stall and a 284h cam .I am running a 750 holley al.heads w/roller tips and al. intake.Tremendous burnouts on power braking with no engine misses but when I jump on the brakes they are gone and the engine dies because I lose vacuum so quickly when I get off the gas.Suggestions?
Old 04-09-2012, 01:55 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Steve, you did not mention what compression you are running. What type of intake, weather it's dual or single. Is the Holley VS or DP. How did you set the timing? Is it vacuum or mechanical advance. Do you have power brakes? Do you know the name of the cam and specs for the 284H? First thing I noticed is the converter. It's too low for the cam you are running.
Old 04-09-2012, 02:24 PM
parts list
Comp Cam 12-250-3(duration 284/296,lift507/510), Holley750 dual line with vacuum secondaries and a Weiand square bore intake.Initial timing set at 10 deg. at idle and after hooking up vacuum advance on dist set at 30 total. At full warm up cylinder running at 460-600 deg. F.Checked vacuum at PCV, 12 at idle.Checked for vacuum leaks and found none.1982 Z-28 with vacuum booster on original brakes.Turbo 350 trans. I realize the cam was bigger than what I needed for the stall I have but still figure there is a way to make it work .botred .60 over,flat top 4 relief pistons and was told +10-1 compression
Old 04-09-2012, 03:03 PM
lg1969's Avatar
Does the vacuum drops as soon you like go the gas pedal? That does not sound right. Usually the manifold vacuum would jump up at first as soon when you let go the gas pedal and it will then settle down once you slow down. I think you just get too much cam for that setup. I'm suprised that your power brakes still works.
383 lack of hp allan b Engine 40 08-18-2011 09:41 PM
lack of motivation rxlmod Hotrodding Basics 27 03-23-2010 06:45 PM
Lack of horses of lack of driver? Nightrider Hotrodders' Lounge 13 04-14-2007 02:18 PM
Lack of Vacuum on blown SBC machgnr Engine 8 07-17-2005 06:31 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
