Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vacuum leaks
Thread: vacuum leaks
Old 06-25-2007, 10:53 AM
Hippie's Avatar
Hippie Hippie is offline
Last journal entry: HEI comparison.
Originally Posted by techinspector1
Now, with the motor already assembled, I was trying to envision some way to check the gasket seal. Here's what I came up with:
What if you made a steel or aluminum plate to cover the carb mounting hole in the intake. Drill one 0.453" hole in the plate to accept a tubeless tire valve. Drill another hole and tap it to accept a 0-15 psi pressure gauge. Back off all intake rockers. Use a bicycle tire pump and attempt to slightly pressurize the manifold plenum/head ports. If you couldn't get any pressure built up to stabilize the gauge, wouldn't that indicate that there is lack of seal somewhere?
Great idea , wish I'd thought of it, don't forget to securely block all vacuum ports on the manifold.
