Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - vacuum leaks
Thread: vacuum leaks
Old 06-25-2007, 06:38 PM
slvrbllt slvrbllt is offline
Last journal entry: 65 mustang 351w efi
I just usually blow cigarette smoke in a vacume source downstream of the throttle plate with the oil cap off and the breather and pcv plugged, it may take a while to get enough smoke,but it will make any little leak show up,such as the throttle shaft.It also will come out around the shaft of some egr's.
