Vacuum Line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2003, 04:38 AM
USMCDCC's Avatar
Post Vacuum Line?
I can't seem to find a vacuum line leading from my manifold to my tranny. I have a tri-power setup and the only things I have coming off the manifold is the heater hose and the PCV line...
How essential is having a vacuum line to the tranny, what type of impact does it have on how the tranny shifts. I took her out for a 1/2 mile spin for the first time and didn't feel like she even made it into second... could this be the cause?
Thx
Old 05-15-2003, 04:41 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Post
What kind of trany.
Old 05-15-2003, 05:46 AM
USMCDCC's Avatar
Post
sorry... c4.
Like I said, didn't seem like she shifted.
Old 05-15-2003, 06:17 AM
troy-curt's Avatar
Post
C4 has to have vacumn to shift out.
Old 05-15-2003, 06:24 AM
USMCDCC's Avatar
Post
That explains it and makes me feel a sigh of relief. Where does the line run to on the tranny, is there a stanard line or should I just get some hose? Can it go to the same vacuum line that the PCV is on?
Old 05-15-2003, 07:17 AM
troy-curt's Avatar
Post
The tranny has a vacumn modulater, there should be a slip on fitting for a rubber hose. The other end should come from the intake direct vacumn. Normally this is a steel line with short rubber at each end
Old 05-15-2003, 07:47 AM
USMCDCC's Avatar
Post
a steel line? That would mean that there should be a specific "steel line setup" for each type of manifold out there.
Like I said, the PCV is coming off the back of the manifold, can the PCV and tranny share the same manifold opening? Is there enough "suction" there is what I'm asking.
Old 05-15-2003, 08:33 AM
New Member
Post
the steel line is mostly just to prevent vacuum collapse since it is such a long run usually. It's easy to bend up and use.
not to mention usualy quite close to exuast.
You have the pcv going into the manifold? Don't you have a fitting on the carb for it?
anyways, no, it's fine for the 2 to share.
[ May 15, 2003: Message edited by: ummduh ]
[ May 15, 2003: Message edited by: ummduh ]</p>
Old 05-15-2003, 09:17 AM
USMCDCC's Avatar
Post
no... won't go to the carb. Tri-power setup and the linkage won't allow that unless I did it to all 3 carbs.
Can get this line at any automotive shop?
Old 05-15-2003, 09:42 AM
EBlack36's Avatar
Rebuilt Excitment
Post
You can use hard brake line and get a barbed fitting for each end.
Old 05-15-2003, 09:53 AM
USMCDCC's Avatar
Post
where does the line connect to the tranny... specofically, where on the tranny? Front passenger side?
Old 05-15-2003, 10:36 AM
New Member
Post
yea just use a length of brake/fuel line and cut it to length. You can run it in a flarer a bit to make a flare, or just don't cut it, leave the fittings on, and you have pre-made flares to hole the rubber line on. Kinda ghetto, but works.
yes, the modulator should be in the front passenger side of the trans.. it's a fairly large canister, really hard to miss!
sorry, didn't notice the tri-power.. your forgiven for not running it to the carbs
Old 05-15-2003, 11:35 AM
USMCDCC's Avatar
Post
any idea what size hose is needed?
Old 05-15-2003, 03:14 PM
adtkart@aol.com
Post
WHat kind of C-4 trans is it? The only ones I have seen have had the modulator in the rear on the right(passenger) corner. The modulator is only about 1 1/2" in diameter and about 2" long. It is right in front of the mount and takes a hose with a 90 Deg bend in it. That is of course if it is a Ford C-4, like they used from mid 60's until the 80's that I know of.
Old 05-15-2003, 04:31 PM
troy-curt's Avatar
Post
The best way to tell the size, is look at it.
