Vacuum line pics/diagram for 305 w/ Qjet? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-31-2007, 09:25 AM
Who knew?
Oh-oh... damage? My bad!
How would I find out or detect if I damaged something by running two pcv's? Could that be the cause of the high-revs at idle? I'll straighten out the tubing situation before we run it again...
Oh, and when we started it again for a few minutes yesterday, there was a strange sound from the left-hand side, like fast pulses of air at high pressure across the edge of sheet metal... I wondered if it was an exhaust manifold gasket problem. Better check that out, too... Since I ran it with two PCV's, I might have done in the valve cover gasket on that side?
Fiscus wrote: "If its idling high you might have a vaccum leak somewhere, or you could be on the fast-idle on the carb. " What does that mean, "on the fast-idle"?
I can search for a vacuum leak, but I think I'll fix that PCV valve issue first: it might be resulting in what the carb sees as a vacuum leak, since they are both plumbed in together...
oh, and thanks for the pics, half-ounce!
detonation 71 chevy c-10 Engine 33 04-29-2010 01:20 PM
Ported Vacuum 72Orange Engine 18 08-07-2006 09:56 PM
Vacuum Advance for a Galaxie, HELP 63 Falcon with a 350 Engine 27 09-30-2005 08:54 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 03:25 PM
69' Camaro RS Vacuum Hide-away Headlights PrimaDude Engine 1 11-18-2002 01:46 AM
