Vacuum line pics/diagram for 305 w/ Qjet?
Hey, folks!
My 14 yr old has his engine rebuilt, and installed. Now for the hard part: where do all those durned hoses go to?? It's a 305 going into an 86 El Camino, which the previous owners had the forethought to partly dismantle over the years... So, we have no idea where many of the vacuum lines go, especially those cool little tiny hard plastic ones that are burned in two somewhere in front of the carb..... '86 305 Chevy with quadrajet, HEI, EGR (what's left of the system), AIR (about half of it, at least), and TH200 (not a 200r4, unfortunately) tranny. I don't know if it is a Cali car or a normal one: I bought it in Misery. Er, Missouri. However you pronounce that state. Any diagrams, pictures, tips, etc... would be appreciated! We have to get it running enough to move it this weekend, as the City is going to tow it Monday if we don't. So, we'll probably haul it into the garage for a while, then back out after they have forgotten us, so we have room to work on it. We really need to get this figured out, as we have not yet started the engine yet for breakin! Thanks for the help, folks, and let's hope it starts! -Joel R |
6 others???
Wow! Okay, questions: what's an EFE, as listed on the diagram? That diagram looks like it might work, but it only shows the lefthand PCV valve. I assume the righthand one just tees in at the same point?
The Air Management Valve: is that for the smog pump? The smog pump and associated plumbing are missing, except for the righthand exhaust manifold still has the AIR tubes in place... I'm wondering what to do about this, too.... Actually, I won't know if that diagram works till I'm out in the heat (103 expected!) tomorrow. But the tubes that I have already identified appear to be the same configuration. What are the differences with the other 6 diagrams? And why so many configurations? Ergh. Anyway, thanks for the help! And so fast, too! Dude!
Thanks, Dale
Hey, Good guess! We found the emissions routing tag on the fan shroud, and it is indeed a YCL. Same diagram as the one you posted.
Funny, my son's car has TWO PCV valves, one in each valve cover.... We just plumbed them together into the same vacuum port, and ignored the EFE and its related TVS, since we don't have the smog pump. The "vac motor" that is mounted on the intake nozzle to the air cleaner housing connects to the heat riser built into the shroud on the right hand exhaust manifold with a flexible metal tube. (As shown on the diagram), but I can't find the EFE. I don't know what it looks like, but there aren't any other components left to hook up to. Oh! Unless it is that metal valve in between the RH exhaust manifold and the y-pipe! That makes sense: it had some sort of vacuum device attached to it. I took that off and pitched it, since it was mostly frozen and half destroyed. Well, I think that answers all of our questions: now we're off to finish fishing wires around the engine compartment, so we can try and start the new engine. Thank you SO MUCH for your help, Dale! |
I just read this thread and hope to find out how u made out staring up. keep us posted. oops, sorry.
glad to hear ive helped you out, i wish you luck in getting her fired up ! ![]() Dale |
2 PCV's
As near as I can tell, the rocker covers are stock. They have brackets on them for mounting the wiring harness clips in, and they are pretty specific. I did install them on the wrong sides, but I'll make it work.
There won't be any problems, running two PCV's, will there? It seems like this would only increase the positive features of the PCV system, but is there something else I don't know about, if I have two PCV's? Also: I thought PCV's were supposed to be run into the air filter housing, instead of through the little vacuum tubes to the carb?? The diagram shows the PCV being hooked up to the vacuum lines. Anyway, thanks, and I'll post again after we start it (hopefully, Tuesday eve!) -Joel |
Distributor gasket, and wiring shield?
Hey, I've got a few questions about things that are baffling me:
The gasket kit came with a fiber ring that is evidently intended to be a gasket for the distributor. I've heard that sometimes they need to be shimmed to mesh correctly with the drive gear and oil pump shaft: how do you tell if it needs one or not? Aren't they supposed to be able to fit without a gasket? I am using an Edelbrock Performer intake: does that affect this issue? Also, there is a metal tube about 5 or 6 inches long that the starter wires pass through. It is evidently a shield to keep the wires safe from the nearby exhaust pipes. Does anyone know where that mounts, or better yet, have any pics to show where it mounts?? Oh, and what's the best way to prime the fuel pump, carb and lines before starting the engine? The tank is currently bone dry, so we will have to get the fuel clear up front to the carb before we try starting. Any tips on making this easier? Thanks, everyone! -Joel R. |
It's alive!
Okay, we got it started! You shoulda seen the smile on my 14 year old's face when his Elky started up for the first time!
Broke it in for 20 minutes, now we are draining the oil and changing the filter, then going to try to figure out why it is idling real fast... More this weekend! Thanks everyone! |
You should only have 1 pcv valve in the opposite valve cover you should have a vent of some sort. The factory used a tube with a 90 degree bend that went from the right hand valve cover aka pass side to the breather.
lots of funky things
Yeah, there is a lot of funky things about this engine, but it certainly has a grommetted hole in each valve cover! There are two filtered plastic fittings into the air cleaner, as is often used with PCV's, but the diagram for this car doesn't show them, nor does it show anything fitting to the air cleaner.
Ah well, I'll just skip that for a bit, unless you have pics? Next we need to get the oil and filter changed, and then check out why it is revving so high at idle. Thanks! |
If its idling high you might have a vaccum leak somewhere, or you could be on the fast-idle on the carb. You only need one pcv valve, ditch the second one and put in a breather.
The pcv valve should plug into the fat fitting 3/8" at the base of the carb the vent would go in the opposite valve cover so it could suck fresh air through the engine to the pcv valve. without the vent the pcv system will NOT work correctly... the vent can be of various type one being a tube that runs to a little filter that is mounted in the breather..another type would be like one of them chrome filter vents that plugs into the valve cover the one that is opposite side of the pcv valve.... Found a pic of the vent tube
Like the others have said, you need ONLY ONE PCV valve. If you run two, it will eventually suck a gasket into the innards of the engine somewhere.
There may be more than one filtered fitting on the aircleaner IF the engine originally came with an A.I.R. pump. They drew air from inside the air cleaner housing before going into the pump. sounds like you are getting there, just please delete one PCV before you do some damage. Mark |
| detonation | 71 chevy c-10 | Engine | 33 | 04-29-2010 12:20 PM |
| Ported Vacuum | 72Orange | Engine | 18 | 08-07-2006 08:56 PM |
| Vacuum Advance for a Galaxie, HELP | 63 Falcon with a 350 | Engine | 27 | 09-30-2005 07:54 AM |
| ok to use same vacuum line for vacuum advance and tranny vacuum modulator? | brian400ex | Engine | 4 | 02-19-2003 02:25 PM |
| 69' Camaro RS Vacuum Hide-away Headlights | PrimaDude | Engine | 1 | 11-18-2002 12:46 AM |
