Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum line pics/diagram for 305 w/ Qjet?
Old 08-12-2007, 11:33 AM
hon_jr hon_jr is offline
2 PCV's
As near as I can tell, the rocker covers are stock. They have brackets on them for mounting the wiring harness clips in, and they are pretty specific. I did install them on the wrong sides, but I'll make it work.
There won't be any problems, running two PCV's, will there? It seems like this would only increase the positive features of the PCV system, but is there something else I don't know about, if I have two PCV's?
Also: I thought PCV's were supposed to be run into the air filter housing, instead of through the little vacuum tubes to the carb?? The diagram shows the PCV being hooked up to the vacuum lines.
Anyway, thanks, and I'll post again after we start it (hopefully, Tuesday eve!)
