!!vacuum lines!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2007, 07:41 PM
Almost there
vacuum lines!!
so i have a 390 ford f-100 that i am in the process of breaking down and regasketing. my question is i don't know if the vacuum lines are going where they need to. i think they are all swapped around. does anyone know where i can find out where to hook what up to.
also th motor has 2 pvs tubs that have a place for 3 vacuum lines to hook up on each one. and then i have a vacuum line on my dist and also on carbs. if i count right i think i have 9 lines altogether. PLEASE HELP IF YOU CAN
also my ac and heater all run by vacuum i was told
Old 11-02-2007, 01:31 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
There is a sticker with a diagram of vacuum line routing somewhere under the hood. If you don't have one, you can order one from Ford.
but, for the most part, the following pieces get ported vacuum:
EGR
ignition (depending on year... more on that below)
small line to charcoal canister
And full vacuum:
brakes
pcv
cruise control
dash ac/heat
large line to charcoal canister
For the ignition if you don't know which one you have its easy to check. Hooke up a piece of vacuum line to it and take the cap off. Suck on the tube while watching the advance. If you can do it relatively easy with sucking on the tube, it should go to ported. If you suck until your tongue hurts and it only moves a little, it goes to manifold.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
vacuum lines sbc..help please! el camino ken Engine 9 10-10-2006 07:41 PM
Ported Vacuum 72Orange Engine 18 08-07-2006 08:56 PM
Should i replace old vacuum lines? Rubberman2003 Engine 6 01-09-2005 11:28 PM
Vacuum Lines riesman20 Engine 2 04-25-2004 02:40 PM
