vacuum lines ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 09:03 AM
vacuum lines ?
I just recently dropped a 350 in a 78 Grand Prix and got rid of all the emissions hoses but there is a black ball like canister that has two small vacuum lines one is purple and the other is black coming from it I believe they control the heater and are ac operations. I not sure what to do with them now. There is no place to hook them up to. Hopefully someone can help me out on this .Thanks in advance.
Old 07-26-2005, 10:36 AM
rbfpezcore's Avatar
Not fast, but loud as hell
Not sure what the lines go to, find a shop manual. But the big black ball like thing is your vacuum storage tank I believe. Do you have power locks or a power trunk? Those are likely candidates.
Old 07-26-2005, 10:44 AM
bet on black's Avatar
hotrodder 4 life
it is probably a vacuum resivior to keep the hvac working normally when the engine is operating under low/no vacuum.
Old 07-26-2005, 10:57 AM
Jmark's Avatar
It needs to be hooked up if you are going to use the a/c or heater. The black hose goes to any "manifold" vacuum source. The purple hose is most likely a small plastic line with a rubber end. It goes to the vacuum selector on the dash to control the vacuum motors for the a/c and heater functions.
Mark
Old 08-01-2005, 03:16 PM
New Member
ac/heat
what exactly does the purple line do.and the black?
Old 08-01-2005, 05:17 PM
Jmark's Avatar
The larger black hose provides vacuum to the "black ball" canister. Its actually a vacuum storage tank. The hard plastic purple line provides a vacuum signal to the dash selector that controls the a/c, heater and defroster doors under the dash.
Old 08-02-2005, 02:27 PM
New Member
i capped of my heater hoses ,its been running hot .now it runs cooler .is there a control that turns off the heater hose?87 cutlass.i may have forgot some thing during reassembly.i live in florida .it ran over 210 .cap the heater hoses its much better.
Old 08-02-2005, 03:56 PM
Jmark's Avatar
Blocking off the heater hoses should have no affect on the systems ability to cool off the engine. Sometimes its quite the opposite. The heater core is just a miniture radiator. Turn on the fan and it will pull more heat from the system.
Old 08-02-2005, 04:20 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Jmark is exactly right, that controls the flapper doors in your heat and air ducts. Without that being hooked up your A/c , heat, and defrost will not work right. Your heater hoses should have no effect on your engine temp. A lot of vehicles have a cable operated valve in one of the heater hoses to cut off the water flow to the heater corewhen you turn your heater off. I do not know if yours is like that or not.
Old 08-02-2005, 05:37 PM
New Member
if you think about it .water goes out of the intake through the heater core back into the engine .with out ever going through the radiator.in florida the ac is chronically on.heater core is doing no cooling either.so the water from the radiator mixes with with heater water .heats the radiator water back up . making it run hotter .caping it off worked for me.10 degrees. i think it sounds logical to , and it was worth a try.has any one else ever done this?
Old 08-02-2005, 05:41 PM
New Member
my out put heater hose goes into the passenger side top of the radiator .not the water pump.89 chevy serpentine drive set up .
Old 08-02-2005, 06:30 PM
Jmark's Avatar
I have thought about it and stand by my earlier post. Blocking off the heater hoses should not affect the engine temp at all.
Old 08-02-2005, 06:41 PM
Lost in the 60's
Wiki Edits: 4
I agree with Jmark plugging the heater hoses should have no effect on the engine temp. If the heating system is working properly you shut the water flow to the heater core off when you turn the heater off. If the heater core was helping to cool the engine as some of you suggest, I think you would be very hot in the car.
Old 08-02-2005, 06:49 PM
New Member
i did put water wetter in it to .i forgot to mention,but a percentage of water comes out of the heater .mixes wit cooled water from the radiator .that would heat the water back up.cut it off the only water going into the engine is radiator water not mixed with hot heater water .it worked .or that watter wetter REALLY does work .if it works that good,im impressed.
Old 08-02-2005, 06:52 PM
Lost in the 60's
Wiki Edits: 4
Good water wetter can make as much as a 10 degree difference.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
