vacuum modulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 03:44 PM
vacuum modulator
Need a new vacuum modulator. Is there any benefit to buying the adjustable ones?
Old 02-04-2011, 03:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can fine tune your shift points with the adjustable modulator valve.
Cole
ADJ vacuum Modulator? Madmax305 Transmission - Rearend 2 11-22-2010 04:40 PM
Th-350 vacuum modulator monzter Transmission - Rearend 12 09-01-2010 10:48 AM
c6 vacuum modulator setup.. Blackhauk90 Transmission - Rearend 2 09-10-2008 07:04 PM
Do I need the vacuum modulator? 65 streeter Transmission - Rearend 4 07-04-2004 02:03 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
