MB = Metering block, almost any carburetor adjustment can be made with a vacuum gauge and you can be confident that it helped the engine run better. I used to keep a vacuum gauge hooked up to all of my carbs and laying in the floor or seat of the vehicle so I could monitor where vacuum was when I was driving. That allowed me to tune the Power Valves for increased drivability and mileage.
PV accounts for about 10 jet sizes in fuel coming in when the vacuum drops to the point of the PV Opening. I used to use the 2 stage valves in most of my stuff so I could get a 5 jet pop when I needed it. I had a 400 SBC in a Suburban that would get almost 20 mpg around town and 23 on the highway. I built a 650 Vacuum secondary with front and rear metering blocks and ran 60 jets in the front 65 jets in the rear and 4.5 / 7.5 PV front and 3.5 / 6.5 PV rear. It made 500ft# TQ and 425RWHP. I was running 305 heads on it with a Dish top 4VR TRW forged piston, pistons milled about .100" to get Block deck close to Zero. Made about 9.8 CR and I ran it on 87 octane with 30* total timing. I drove it for almost 10 years, pulling towing trailers, back and forth to Charlotte and one weekend I was at a race pulling with the dually and the shop got robbed and Suburban got stolen. |
Sounds like a vacuum leak somewhere because as you turn the idle screw out you should increase RPM and Vacuum until it starts going the other way from getting over lean.
Most cars will run in the 12"-16" range at idle and then vacuum drops as you open the throttle under load, driving down the road. The vacuum signal that is constant is for stuff like your power brakes so they are not ever lacking. The port that moves is the one you use to measure engine performance. |
ok, I'm so over tuning this like a retard... I wish someone could walk me through tuning the carb and timing with a dyno or at the track (I'm not asking anyone for this but i wish I could around here). I threw on my 750 DP Holley completely unsetup just to see what would happen. The engine still stumbles and misses but seems to do this higher into the vacuum even at 16"-17" idling at 1500 rpm. I'm really thinking that the vacuum gauge fluctuating is due to the carb being mis adjusted. I have single wire O2s in the collectors of my headers but I don't have gauges for them yet. I waited until the engine/exhaust was good and hot (idle/reving in driveway) and took some readings from the O2s with a DVOM. I am idling around .800-.850 mv which is lean. I rev the engine up hold it at like 3000 rpm and no real distinct change is noticed. I realize it's not WOT or even accelerating just a really high idle but I'm beginning to get very discouraged in tuning the carb (1406 edelbrock or 750 holley dp) this is just not a strong suit of mine
Could the stumble/miss at idle be a combination of big chamber heads and short/cooler plugs (R43T), and/or a mal adjusted carburetor and timing which is at 12 degrees and manifold vacuum bouncing around 10" (bouncing I'm assuming is due to the miss/stumble at idle)? Sorry for this thread getting ridiculously long but there is LOTS of good information here! Thanks guys!
The motor wouldn't even start if you are @ 26* inital.
Maybe if you used a jumper engine it would. |
Do a comp check. Sounds like a valve problem.
a little update. I found the heat riser block off on my edelbrock intake loose and the gasket was extremely hard and brittle. Replaced the gasket and tightened down the bolts thinking this may be the reason the vacuum gauge is bouncing around at idle.... Nope. Still hunting for whatever may be causing this. Now the engine is running really fat, bogging and popping on hard acceleration.
I'm surprised that no one has mentioned that with a cam lobe separation of 106 degrees you will get a choppy idle, and an unsteady vacuum reading because of it! Most stock cams have a lobe sep. around 112 degrees or more for a smooth idle and steady vacuum.
If your vac is 12 degrees or less at idle your carburetor may need a power valve with a lower opening value. FWIW ssmonty Last edited by ssmonty; 04-01-2012 at 03:53 PM. |
SSmonty, ya... I knew with the 106 LSA it would be a choppy idle. I wanted that, but I wasn't sure if the vacuum would bounce as well. I guess it only makes sense. Since I now have the Holley on there, you're prlly right about the power valve. I will look into a lower number power valve. What is it... 2 numbers lower than your lowest vacuum reading?
I'm certain its lower than that. More like divide the lowest vacuum reading by 2, then subtract 2 from the results, but I can't say for sure. I never had to replace one unless it was blown.
Perhaps someone that's more qualified than myself will chime in? ssmonty |
Ok... so I replaced the R43T delco plugs with R44TS plugs and they barely fit with the pistons. I made sure to double check. I also retimed the engine and ran a different curve. I was at 14 degrees initial and 34 total all in by 3500 rpm. I changed it to 17 degrees initial and 32 total all in by 3000 but I still get the pop and bogg on hard acceleration. It has to be the carb giving me troubles now. I pulled the holley off and blew it apart. Here's some info, let me know if anything sounds wacked. It is a 4777-2 750 DP mechanical secondaries. Main jets are 76 secondary jets are 67, main and secondary squirters are 25. Using yellow/orange pump cam in top hole. Also the PV is 6.5. Since my idle vacuum is about 10" I was thinking I should get a 4.5 or a 3.5 PV. But this is what it is right now. Does anyone see a reason I would be getting a bogg, pop and low power on hard acceleration? The old plugs (R43T) look carboned up like too much fuel so going off of that it seems the carb is way too rich. Can anyone suggest a better setup for this carb? Here are some numbers off of the metering block if it helps anyone. Main metering block L47772, 8539, 8520 and 5. Secondary metering block L47772, 6497 and 650. Thanks in advance!
Broken valve spring, bad vavle, bad cam???????
Have you done a comp. check? |
I have not done a compression test yet. None of the plugs I took out look like there is anything wrong other than too much fuel. It is a brand new engine with maybe a couple hours of run time on it. Less then 20 miles driven even and everything is brand new. The vacuum needle only bounces at idle. Part throttle/high idle the vacuum needle is solid as a rock. I may need to adjust the valves slightly but I'm really doubting that as I was very meticulous in assembling this engine.
| vacuum gauge needle fluctuating really fast | glhx | Engine | 4 | 05-21-2010 05:54 AM |
| Bouncing tach needle | GCD1962 | Electrical | 0 | 08-15-2008 04:27 PM |
| Bouncing fuel gauge needle | 1970Chevy | General Rodding Tech | 9 | 07-09-2007 01:07 AM |
| Vacuum gauge needle jumps | JG700 | Engine | 2 | 06-24-2007 06:41 PM |
| Bouncing Timing | MI2600 | Engine | 6 | 09-04-2003 08:23 AM |
