Which vacuum port do I use- Motorcraft 2bbl- pics - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2011, 04:56 PM
I am adapting a Motorcraft 2bbl 1.08 venturi
to a 76' land cruiser with the inline six 4 liter
engine.
I mocked up the carb wth adapter on a spare intake and not sure which port to pull vac for my vacuum advance distributor.
The ( A) port looks to be above the throttle plate- not sure what it originally attached to.
and (B) looks to be at throttle plate level.
(B) was the choke pull off which I am not going to use. I am using a manual choke.
(C) would be full vac off the manifold so that probably wont work.
How about 5 in the next pic- is spark port
ported vacuum?
an opinions on ported vacuum for this ?
Old 12-06-2011, 05:10 PM
I found this online but I don't have some of these ports.
I don't have 3 or 4
#1 is ( I assume) A in the first pic
Name:	Screen Shot 2011-12-06 at 12.03.24 AM.JPG
Old 12-06-2011, 05:19 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
If it were me, I'd install the carb and fire up the engine to find out what vacuum port did what. Foolproof that way.
Old 12-06-2011, 05:44 PM
DoubleVision's Avatar
Most of the time engines like manifold vacuum over ported on spark advance. But there are some factors. SBC`s like manifold vacuum to vacuum advance. However, why is because Idle and part throttle mixtures are lean. Lean mixtures burn slower than do rich mixtures. Since it`s lean and burns slower, power benefits from the early spark advance. However, if your intake is based on a single plane design, it may run richer, or the tune may perfer it richer. I would experiment with both manifold and ported vacuum then use whichever one gave it the better power.
1994 Geo/Tracker no vacuum at the engine port ort to t vacuum port to the mbaskettjr Hotrodding Basics 2 09-08-2011 08:08 PM
MotorCraft 2100 Vacuum help. =( Grouper Engine 3 10-25-2008 12:50 AM
Where is the timed vacuum port and constant port on my Edelbrock Q-jet? Porchev Engine 2 11-22-2007 08:04 PM
Oil in vacuum port bct Engine 4 12-29-2004 07:18 PM
Mustang V-6 motorcraft 2150 carb. vacuum routing? 87442lover Engine 1 04-24-2003 10:51 AM
