I need an educated opinion. What vac. port should I put the line from the modulator on a t-400 to? The port in the carb base or the port in the intake manifold. I put the booster line to the manifold and had them both coming off a tee but one of my Buds said that I should split them to different ports. What do you Guys think? GK
As long as it is full manifold vacuum (under the throttle plates not ported) you will be fine. Either port is good, using a tee is fine too...there is no flow in this application only a reference signal.
Thanks 4 Jaw, I thought the same thing but you know when somebody says something you start to second guess your self. I went and split them up today but I didn't have to, Oh well it won't hurt anything, put the trans line to the base of the carb....thanks again......GlennK
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
