vacuum ports - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2002, 03:49 PM
46_stvblt's Avatar
Post vacuum ports
I need an educated opinion. What vac. port should I put the line from the modulator on a t-400 to? The port in the carb base or the port in the intake manifold. I put the booster line to the manifold and had them both coming off a tee but one of my Buds said that I should split them to different ports. What do you Guys think? GK
Old 11-26-2002, 03:56 PM
4 Jaw Chuck's Avatar
Post
As long as it is full manifold vacuum (under the throttle plates not ported) you will be fine. Either port is good, using a tee is fine too...there is no flow in this application only a reference signal.
— Han Solo
Old 11-26-2002, 04:12 PM
46_stvblt's Avatar
Post
Thanks 4 Jaw, I thought the same thing but you know when somebody says something you start to second guess your self. I went and split them up today but I didn't have to, Oh well it won't hurt anything, put the trans line to the base of the carb....thanks again......GlennK
