Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #16
Old 08-01-2008, 02:05 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
re: Vacuum Pump
I can't find an AC supply house close around here. Has anyone obtained the oil via some other outlet/store? A friend says he uses PAG oil like you put on your car AC system, but that stuff's expensive.
Old 08-01-2008, 02:10 PM
perrib perrib is offline
re: Vacuum Pump
Car Quest has ester that works with R-12 and R-134 in pints and quarts. Some late model compressors are oil specific.
Old 08-06-2008, 11:50 AM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Ford Service Technician
re: Vacuum Pump
doesn't have to be an A/C supply - your local Bumper to Bumper or NAPA should be able to get you vacuum pump oil.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Vacuum Pump"
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 11:51 AM
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 17 10-09-2004 09:58 PM
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 64 09-13-2004 07:33 PM
vacuum advance help batman09 Engine 14 09-09-2004 08:42 PM
1928 Chevy Truck Vacuum Fule Pump ginger Engine 5 07-25-2003 01:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
