Hotrodders Bulletin Board
#1
Vacuum Pump
I inherited a Robinair brand vacuum pump from my Dad. Anyone know anything about them in terms of quality, etc. Unfortunately, there were no instructions. I'll need some expert guidance that I know we have here.
#2
re: Vacuum Pump
Hi,
On this link page click on manuals, then click on your model # Hope this helps, Rich http://www.robinair.com/needhelp/needhelp.htm |
#3
vacuum pump
Hey,Mi,
these pumps are indispensable when doing a/c work.Robinair has some of the better tools for this. Some commercial or professional grade,some for diy. After doing a repair on an a/c system you want air and moisture out.You would hook that pump to a port on the system and take the vacuum in the system down to preferably 28Hg.Since water vaporizes at 32Hg. This would extract all the air and water out of the system.The longer you leave it on the system the better the results.Usually an hour would suffice.You would use it on the center port or yellow line on a set of manifold gauges so you can monitor the depth of vacuum. also it would give you indications of any leaks in the system,if it wont hold vacuum it wont hold gas,hence the system wont work.If you inherited it from your pops it may be set up for R-12 systems.You may have to get an adapter to convert the port on the pump to a fitting compatable with the later model r-134 systems.Although it can have a myriad of other uses. |
#4
re: Vacuum Pump
Thanks, Rich and Bad. My Dad passed almost 20 years ago. It always gives me a good feeling to be able to use his old tools and equipment.
#6
re: Vacuum Pump
Old Robinaire equipment was top of the line. The only problem could be if it has been tipped over and the oil got out. I also have a some of my dads tools including a screwdriver he made in metal shop in the early 40's.
#7
re: Vacuum Pump
I've got a Robinair vacuum pump and it works great. You should really change the oil often to keep them from wearing themselves out... the manual recommends changing it after every use.
#8
re: Vacuum Pump
I finally got a pic of the vacuum pump. I researched the Robinaire site but there's no way I can send them a pic.
Anyone know about the care and feeding of this? I have no idea what kind of oil it takes or how much. |
#9
vac pump
Hey again MI,
Wow that thing belongs in a museum! But all of them are basically the same.If you remove the cover you'll find a small pump inside,somewhat similar to a 12v tire pump.There should be an access port for oil,(small drain plug)if you are lucky maybe even a sight port to get a visual on the oil level.These things get pretty warm after extended use so I would change the oil after 10-20 hrs. use.It has a small piston and a small crankcase the port would be below the piston in the crankcase.Best to use the recommended light weight pump oil.That looks to be an early commercial model so if it works it should be a pretty good unit. Good Luck Badwrench 3 |
#10
re: Vacuum Pump
Just stop at any refrigeration supply place and ask for vacuum pump oil. Slod by the quart or gallon. It's a highly refined mineral oil just for vacuum pumps. The reason you change oil after every use is to get rid of any water that may contanimate the oil from the system you are pumping down. Good luck and enjoy your stuff. Tom F.
#11
re: Vacuum Pump
Thanks for the info, guys.
I called Robinair today, which is apparently part of SPX now. The guy there was less than helpful and essentially said he couldn't/wouldn't help me. He gave me an e-mail address that turned out to be worthless. I opened the unit up yesterday and took some pics which I will try to attach. There is a port (tube) that exits out the back which must be for the oil, but there's no sight glass. I was hoping Robinair could help out there. Is there a problem if I overfill it? |
#12
Vacum Pump
Wow!!!
I made an assumption(spelled "***-me") that this was going to be a run of the mill pump.This one is similar to early refrigerator (almost ice box era) refrigerant pumps.They were encased and totally submerged in a nasty black oily substance to dissipate heat.Hence the vanes around the outside of the tank.As far as service or maintenance on this beast I'm lost.Disassembled one once just out of curiosity,what a mess.But did come away with a sweat little piston,made a cool gearshift knob for a 48 panhead. |
#13
re: Vacuum Pump
During my "totally expert" disassembly, I managed to tip the unit and a light oil spilled out of the intake or exhaust port. I'm guessing that was the vacuum pump oil. I'll have to try to get some more.
The unit has been setting for over 20 years so it might be best to totally empty and refill it. The amount of refill is the question. I'm told if they're over filled they "spit" the excess out...??? I'll try filling up to the rear port level while the unit is upright. Any thoughts? |
#14
re: Vacuum Pump
If there is a drain for the oil just measure hhow much comes out and put that much back plus an ounce or two. When in use they don't use or lose a lot of oil, so chances are it has the correct amount of oil in it.
Most vacuum pumps today have an additional port on them called a ballest. The ballest is used to help eliminate moisture from the oil when the unit is running. When evacuating a refrigerant system the vacuum pump will quickly remove the air/refrigerant in the system and start to put the system in a deep vacuum. This takes time and during this pumping very little is passing through the pump as it works to pull the deep vacuum on the system and allow any moisture to evaporate and be drawn out. If there is a ballest valve it can be opened at this time to allow some air to pass through the crankcase and take moisture with it. 29.92 inches of mercury is a perfect vacuum. Very hard to accurately read a deep vacuum on a gauge so a micron gauge is used. Squido |
#15
re: Vacuum Pump
i have an everco vacuum pump that is like the pump in yours, mine is not in any kind of enclosure.
mine uses 12 oz of either 10W40 motor oil or A/C vacuum pump oil. i have always used vacuum pump oil. i change the oil in mine after ever fifth use unless i have a dirty system, then i change it right away. if it hasn't been used for a couple of months, i change the oil before i use it. to drain mine, there is a drain plug on the bottom of the pump. to refill it, i simply hook a hose to the suction fitting & put the other end of the hose in the oil, i turn the pump on and draw the oil into the pump. there is no danger of me over filling it, the excess will be blown out the exhaust fitting. this is a guess, but i believe the exhaust port on yours is the bottom fitting. yours looks to be a little taller than mine, i would put 16 oz in it & see if it spits any out the exhaust port. |
Back to top |
Similar Threads for: "Vacuum Pump"
| Do I need vacuum advance? (Long Post) | Chevy21 | Engine | 49 | 10-25-2007 12:51 PM |
| Ford 1 and 2 piece fuel pump eccentrics | lluciano77 | Engine | 17 | 10-09-2004 10:58 PM |
| Vacuum advance hooked up directly to manifold....is this bad????? | Steve-0321 | Engine | 64 | 09-13-2004 08:33 PM |
| vacuum advance help | batman09 | Engine | 14 | 09-09-2004 09:42 PM |
| 1928 Chevy Truck Vacuum Fule Pump | ginger | Engine | 5 | 07-25-2003 02:42 PM |
