Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum pump to bleed brakes
Old 12-01-2009, 10:06 PM
stimpy stimpy is offline
when I worked on the line as a wrench we had problems with the mighty vac pulling air past the seals on some older cars ( mostly fords with the unsupported cups ) I refused to use one after awhile ( either did it the 2 man way or by gravity ) , I just bought a cheap power bleeder ( motive power) for less than $150 from summit and it works great .
