Vacuum Pump Selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2010, 07:33 PM
I am having to put a vacuum pump in my car to help with the power brakes. I have found 3 or 4 on the market ranging from about $200 - $350. The only difference I can find is the size. What I am concerned about is the recovery time and the noise level. And anything else that might be good to know about these units.
Any comment would be greatly appreciated.
Old 12-19-2010, 07:53 PM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I run the one master power brake sells, I went that direction because it has a pressure switch that cuts the pump off when vacuum is achieved, that also applies with your foot holding brake.
My pump is located under the car and I have side pipes that are loud so I only here the pump before I fire the car. I messed with the noise for grins just to see if I could knock it down some.
Here is what I found that little muffler is about as quiet as it gets, tried to run a rubber tube and attach the muffler at the end , no real difference in db level. about the best way I figure to get it down might be to completely enclosed it like you would do to a computer. You could trunk mount it that way.
Something else I tried was a reservoir tank to see if I could cut down the cycle time, and all I learned there was that it made the pump run longer because of the volume increase using a reservoir.
I would be interested to know the pump you end up using, for more knowledge.
Here is a link you may not have thought of RVs use these pumps and I would guess noise is an important feature in that application; http://www.readybrake.com/electricvacuumpump.html
As I said before my car is plenty loud and I do not here the thing once the motor is running.. What's that saying loud pipes hides the vacuum pump noise or was that saves lives ? So there it is all I can think of regarding the use of an electric vacuum pump, if you think of another question let me know...
Old 12-20-2010, 07:47 PM
Thanks for the input. I checked out the trailer pump but it only takes me up to 15". Master Power brakes tells me I need 18" for it to work right (I've got an underfloor MPbrakes unit).
Hand vacuum pump oldred Garage - Tools 5 08-18-2010 11:24 AM
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 66 08-21-2009 06:37 PM
vacuum hose routing for wiper motor and washer pump help needed atotalnincompoop Hotrodding Basics 2 06-11-2009 04:36 PM
vacuum canister or pump novadan Suspension - Brakes - Steering 2 12-08-2006 08:28 PM
vacuum advance help batman09 Engine 14 09-09-2004 09:42 PM
