Vacuum question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 03:39 PM
Supporter of the 4.3 liter V6
Vacuum question
I took my distributor (HEI) out of my truck to replace pick-up coil and refurbish it in general, not realizing there was a small round seal underneath it. Is this an oil seal or a vacuum seal? Mainly could i have a vacuum leak at the distributor shaft since i didnt replace the seal??
Old 03-03-2012, 04:13 PM
bigblockragtop's Avatar
If I am understanding you correctly which maybe I am not so... If you are talking about taking out the distributor and the flat gasket under it between the intake manifold and the part of the distributor that rests on it then you would get an oil leak not a vaccum leak
Old 03-03-2012, 04:48 PM
maverickmechanic13's Avatar
I'll have a beer with that.
Last journal entry: My Trans Am
bigblockragtop is right. The only seal under that dizzy should be a flat paper gasket that keeps oil from spitting out.
Old 03-03-2012, 05:20 PM
Yes that is what i am referring to. When i did the job i had no idea there was a gasket there so i put it back on without one. Since there is no oil spewing out it should be fine then right? And you guys are sure there is no vacuum there?? Thanks for the quick replys by the way, i appreciate it
Old 03-03-2012, 05:25 PM
I think you should put the gasket back in my opinion. It will leak if you drive it hard at all. It takes 2 seconds to pop it out and in so why not.
Old 03-03-2012, 05:47 PM
Bigblock you are right. I live at autozone anyways, a 2 dollar gasket won't break me
Old 03-03-2012, 05:59 PM
excellent I need a box of those diamond grip gloves(can't find them anywhere else) grab me a box Thanks good luck
Old 03-03-2012, 06:28 PM
Haha thank you sir!
need more vacuum question dar130 Suspension - Brakes - Steering 5 07-18-2010 08:37 AM
vacuum tuning question ocbaud Engine 1 12-25-2007 08:42 AM
vacuum question..... burntrack Engine 1 03-28-2006 10:21 AM
Another Vacuum Question bluesman123 Engine 8 09-05-2003 09:10 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
