Vacuum Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2012, 11:34 PM
Vacuum Question
I have a small block Chevy with a demon carb. I Have the vacuum tank hose, trans modulator hose and brake booster hose going to a connector screwed into the back of the manifold. Idle is a little rough. I was messing with my car yesterday and forgot to plug the modulator hose in and the engine was running smooth. When I plugged the modulator back the idle was rough again. Any suggestions on why this happens? Mahalos.
Old 10-13-2012, 09:01 AM
Wiki Edits: 27
air leak,
Is the Modulator good, sounds like the diaphram is leaking and too much air getting into the intake. A hand pump vacuum tester is handy to have , I have seen guys suck on the tube to see if it holds vacuum, not aa me, if the modulator hose is long enough, run the engine, pinch the hose so it won't leak, pull of the hose put your finger on the end . unkink the hose and you should feel some vacuum in the hose. ,a lot of times a leaking modulator will allow oil to get into the hose..
Old 10-13-2012, 11:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What is the initial timing set at? What's the cam specs?
Might be pointing to the idle circuit being too rich. The added air from the open modulator fitting leaned it back out and the idle smoothed out. Have you adjusted the idle mixture screws to the highest vacuum/idle speed? Is the curb idle screw adjusted so far in that the idle mixture screws don't do anything (or very little) when the screws are turned in or out?
Old 10-13-2012, 08:28 PM
bigdog7373's Avatar
Of course it's fast
Since the engine runs better with it getting more air then you need to check your idle mixture. Sounds like it's rich. What's your timing at?
Vacuum question ChadGresham Engine 7 03-03-2012 06:28 PM
need more vacuum question dar130 Suspension - Brakes - Steering 5 07-18-2010 08:37 AM
vacuum question..... burntrack Engine 1 03-28-2006 10:21 AM
Another Vacuum Question bluesman123 Engine 8 09-05-2003 09:10 AM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
