Vacuum reading with new cam sbc 350 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-05-2010, 01:18 PM
Lets say 1 cam/timing chain assembly has a plus or minus 1 degree tolerance and the second has the same but 1 is advance 1 degree and the other is retarded 1 degree now you have a 2 degree difference between the 2 cams.
  #17 (permalink)
Old 09-05-2010, 01:48 PM
Well guys some great news I just got done replacing my brake booster with a new one and I took out my brass fitting in the back of my intake that had my vacuum modulator hooked up to and it must have been sucking in a very small amount of air even though you could not tell it.
But long story short I plugged it back up and t fitted it into my vacuum advance line hookup and with that change and my new brake booster in I just happened to hook up my vacuum gauge again and now I have an amazing 19 inches of vacuum at idle and a very nice steady needle. Was steady before but was at 15 and that was with vacuum advance and all things hooked up.
Thing still ran just fine before these changes except while driving and slowing down with the brake booster leaking inside idle would pick up just a hair then go back down but all is very good now.
Thanks again.
Eric
  #18 (permalink)
Old 09-05-2010, 05:37 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
19 " just like you were expect'n ,,,that's plenty good suction at idle, good thread, good digg'n there eric.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 05:10 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Wich cam would you choose between these two? sbc 350 eric32 Engine 11 06-22-2009 05:57 PM
Timing woes on SBC 350 with bigger cam. Brawler Engine 5 09-07-2007 04:33 PM
Will this cam have more vacuum in a 350 Mr. Wormy Engine 1 06-11-2007 11:14 PM
