vacuum reserve canister - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2009, 11:50 PM
usmcsawgunner's Avatar
do those vacuum reserve canister just improve the power brakes with a lopey cam or will it improve the overall vacuum of the motor? also where would I put the vacuum gauge tube (for the gauge thats hooked up in the truck?)
Old 05-05-2009, 11:53 PM
fast68's Avatar
likes chevy trucks & boobies
just for reserve vacuum for things that need vacuum such as the a/c heater control panel and such as well. at least stock vacuum balls and canisters anyways.
Old 05-06-2009, 12:13 AM
4 Jaw Chuck's Avatar
I thought you were an expert?
J/K
The gauge goes to manifold vacuum.
Vacuum reserve canisters are mainly for vacuum assisted power brakes.
Old 05-06-2009, 12:44 AM
powerrodsmike's Avatar
Wiki Edits: 161
They help, even with a lopey cam, for a couple of power brake applications after an above idle run. The extra vacuum does help...Your motor does make a fair amount of vacuum when it is decelerating, this is what pulls the vacuum down in the canister..The canister has a check valve, so even when the motor is running at a low vacuum, there is still enough vacuum in the canister to allow the brake booster to work...a few times..then you have to run the motor up some more.
later, mikey
BE different....ACT normal.
Old 05-14-2009, 12:44 PM
Putting a larger engine into a small engine bay required me to use a smaller brake booster. By using a reserve canister, will this bring my braking power back to where it should be? Thanks!
Old 05-14-2009, 12:47 PM
Banned
No. It may help a little, but only a slight amount. In your case you need a larger brake booster.
Old 05-14-2009, 12:59 PM
Or . . . . a stronger leg.
Pat
Old 05-14-2009, 02:37 PM
ericnova72's Avatar
More for Less Racer
Or just go to manual brakes, you don't need that grandma vacuum assist anyway.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
vacuum gauge readings GMR Engine 11 08-25-2008 12:03 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
