Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Vacuum Reserve Canister Plumbing?
Old 11-04-2012, 12:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Curmudgeon29 View Post
I ordered a vacuum canister last week and have a question about placement. My engine makes only 9 " of vacuum at idle, 18" at 1200 RPM and I am running a dual diaphram 7" booster, one good stop - then hard pedal, but you can still lock'em up.
My question is on placement of the can. I figure it should as close to the booster as possible but I'm going to have to run about 5'of
vacuum hose from the manifold to the can then 2' back to the booster. Will this have an adverse effect on what what I'm trying to accomplish? I don't want to run a noisey Vac pump if possible!
You would like the reservoir as close to the booster as possible, but 2' from the booster is not too far away. Just don't expect miracles.
The Following User Says Thank You to cobalt327 For This Useful Post:
Curmudgeon29 (11-04-2012)
