vacuum secondary or douple pumper - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-30-2013, 07:59 PM
Banned
Originally Posted by vinniekq2 View Post
velocity where?
in the carbs venturi or in the intake runner?
Well, velocity in the runner can impact volume so it becomes important only because of its effect on volume and condition. If the heads can effectively maintain a high quality of intake charge and fill the cylinder then the velocity can be lowered and you will make more power (hence larger ports are used when going after racing power numbers).
velocity in the carb can have a significant impact on "condition" depending on how well the carb can atomize and disperse the fuel- as the quality of the carb goes up the need for high velocity goes down, you can then run larger venturi and have more volume for a given pressure differential across the top and bottom of the carb. Hence a good carb will have lower velocity with better condition and more volume.
velocity is only one way of many to affect volume and condition (which is what you're really concerned with).
  #32 (permalink)
Old 01-30-2013, 08:05 PM
spinn's Avatar
Disagree, I will get back to this. Part of it, if you left out all the Will, Only, Really's . You bring up some topics of discussion.
750 double pumper or vacuum secondary stroker444 Engine 28 11-15-2010 11:24 AM
how much vacuum for secondary's PiperDavid14 Engine 3 09-17-2010 04:57 PM
750 double pumper or 650 Vacuum Jouba General Rodding Tech 1 02-17-2009 02:56 PM
vacuum secondary tuning dirtydave Engine 14 09-13-2004 07:53 PM
engine vacuum and vacuum secondary carbs poorhighschooler Engine 3 04-30-2003 08:40 PM
