vacuum secondary or douple pumper
Hey guys, I'm sure you've answered this 100 times. I know this isn't a hot rod question so I appoligize. I have a mildly built 454, I'd guess around 400hp. It is in a heavy 1 ton truck with a 5 speed manual. I use this truck to tow a good bit and just cruise around. I have a 750 holley vacuum secondary on it now. It does pretty good for cruising but when loaded I have to get the rpms up enough for the secondaries to open. I'd rather have a douple pumper so if I push the throttle enough I can open the secondaries at a lower rpm. I tried a really light spring in the secondaries but without the pump shot it makes it bog when they open. Every place I read says you don't want a double pumper for towing but no one says why. Would it be a bad idea to switch to a dp? Also would it kill my fuel mileage? I'm getting about 11mpg empty with the vs... pretty good i think for a 6600lb truck.
I had tbi and it ran terrible. I had the chip made for the cam and heads. I switched to holley vs and it made it feel like a whole new engine. Why do you recommend the q jet? I'm sure the dp will use more fuel if i don't keep my foot out of it, but yea, that will be hard to do.
Most likely if you switch to a double pumper while towing if you don't have the rpms up it will probably bog. Why don't you just try going up a couple sizes on the jets on your 750 carb. Go from 72 to 74 on the front and on the rear go from 76 to 78. Keep an eye on the plugs to see if running too rich.
It is a 4160, no secondary metering block.
DP's are better off with manual trans so for your application with 5 speed that is one good thing, personally for a rig like that I would want more control over the secondaries and the DP will do that, add to that the right gear selection.
MPG > guess you could sqeeze the same out the same milage as a vacuum secondary if you keep you foot out of it. Going out and dropping >400 bucks for a new one may not be worth the $$$ though ??? your call. |
vacuum secondary or double pumper
You can always convert the 4160 secondary to a 4150. Here is the kit and instructions. This way you will have a way to adjust the fuel. http://holley.com/data/Products/Tech...110%20scan.pdf
no way in hell would I put a DP carb on that. Nor would I bother wasting money on a quadrajet. Your current carb will work perfectly- if it is cleaned up and tuned properly.
BTW, why do you want your secondaries to open sooner? That would be the first question I would want to answer. Next, if you need to change your pump cam, do it. You can also change your squirters if that is the problem. And as suggested I would convert to 4150 immediately. You have an untuned carb, and any untuned carb is NOT going to perform well. Changing to a different untuned carb still will not fix your problem. |
If your looking to buy a new carb I would sugest a Eldebrock 750 for this application due to you mostly are using the truck for towing. my dad had a 750 vacume secondary holley on his 454 in a 78 dually and you could not keep power valves in it. He switched to the Eldelbrock and truck ran well. In my opinion a Holley carb is intended for performance applications. I think you will be pleased if you decide to go with the Eldebrock.
a 750 with mechanical secondaries is too big, with vacuum secondaries it really isn't an issue as they only open with enough air flow, and not a second sooner no matter how hard you stomp on the throttle.
530 FT lbs @ 4500 RPM Cam I'm using is Comp Cam 280 HFT There is lope to it when it's idling. |
| 750 double pumper or vacuum secondary | stroker444 | Engine | 30 | 11-15-2010 10:24 AM |
| how much vacuum for secondary's | PiperDavid14 | Engine | 3 | 09-17-2010 03:57 PM |
| 750 double pumper or 650 Vacuum | Jouba | General Rodding Tech | 1 | 02-17-2009 01:56 PM |
| vacuum secondary tuning | dirtydave | Engine | 14 | 09-13-2004 06:53 PM |
| engine vacuum and vacuum secondary carbs | poorhighschooler | Engine | 3 | 04-30-2003 07:40 PM |
