which vacuum switch do you use for 700r4 TC lockup system? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2012, 10:35 AM
I'm looking at 2 adjustable switches, 1-6" or 6-22" of vacuum. Which switch do you guys use? It would seem that if you're engine is a stock-mild one then you'd need 6-22" version.... correct? (mine will be on a '76 C10 with a mild 350)
Old 09-08-2012, 04:10 AM
SSedan64's Avatar
Yes, for a stock to mildly cammed engine the 6-22" switch is what you'll need.
Old 09-10-2012, 07:03 AM
Last journal entry: Still running strong
I'm using one from a Chevy truck,it switches at 7.5 ins. of vac.This seems to be just about right.
700r4 Vacuum Switch Cycling cadmanof50s Transmission - Rearend 24 09-06-2016 12:11 PM
700r4 lockup, manual or vacuum? mooselee Transmission - Rearend 10 09-16-2012 07:49 PM
700r4 lockup switch 1972RedNeck Transmission - Rearend 1 01-03-2011 05:58 PM
Operation of Vacuum Switch for TCC Lockup JohnTN Transmission - Rearend 1 07-10-2009 11:23 PM
700r4 manual lockup switch Boosted89RS Transmission - Rearend 8 03-25-2008 10:52 AM
