Vacuum too low at idle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2008, 11:20 PM
406 bug's Avatar
9.82 @ 139mph
Just fired new sbc 406 and it sounds good. However, Iam not sure if the vacuum readings are what they should be for this motor.
406ci / afr 210 heads / super victor manifold/ 830hp series holley/ full roller mechanical - duration 248/254@50 with .577/.583 lift. 1 7/8 in headers. 4:11 rear , 28" tire, t-400 , 4000 stall , 2200 lb with driver.
My vacuum readings are: 7" @ 800rpm
8" @ 1000rpm
16 @ 2000rpm
This is with no load, since the transmission is not yet installed.
Are these readings unusual for this motor????
Old 09-30-2008, 11:33 PM
Jmark's Avatar
What is your initial timing set at? It will play a big part in the vacuum readings.
Old 09-30-2008, 11:43 PM
406 bug's Avatar
9.82 @ 139mph
I'm just a bit embarrassed here Jmark, since its brand new I eyeballed it at about 10 btdc. I will put a light on it tomorrow. Thanks
Old 10-01-2008, 09:17 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
vacuum to low what is to low? 0 is to low, if you have a good size cam all the timing adjustments in the world will not change it.
My car has similar readings and runs great, it does shake a lot and can be seen rocking back and forth at the lights 900-950 rpm, have to run an electric vacuum pump for the brake booster ............... but that is all in the combination of parts.
Definitely time it with a lite, with a modified motor chances are the vac will still be on the low side compared to a stock motor.
Old 10-01-2008, 09:41 AM
lg1969's Avatar
Google "Tunnel Ram 406"
406bug, If the manifold vacuum is that low I would replace the power valve to less then 6.5 to 4.5. There is chance the plugs will load up on you too frequent. I have a funny feeling the vaccuum will go below 6.5" when have it in gear.
Old 10-01-2008, 12:04 PM
406 bug's Avatar
9.82 @ 139mph
Thats my fear, when I rebuild the carb- I found 4.5 pvs and figured it would be best to return it to stock specs (6.5s) so I would have a baseline to work from.
Old 10-01-2008, 12:49 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
You did not give the camshaft valve ISA specification. If it is lower then say 110*, and closer to 108*, or 106*, it will have a rough/bumpy idle, with lower vacuum readings.
My 2 cents worth.
Old 10-01-2008, 01:04 PM
your base timing is way to low for that cam, needs to be 18*+ which does help idle Hg....
read the "initial" timing section in this very good article:
http://www.gnetworks.com/v4files/bar...withimages.pdf
minumum operating range of that cam is approx 2500 so read the Hg at 3000+ to indicate cruise Hg....
Old 10-01-2008, 07:46 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
7" @ 800rpm
Wow - I'm surprised you got the beast to idle at 800... Guess those extra inches are at work here.
Old 10-01-2008, 10:22 PM
406 bug's Avatar
9.82 @ 139mph
Put the timing light on this pm and the initial timing was higher than I thought.
14deg. bumped it up to 18 and the idle vacuum is 8in@850rpm. Motor seem to be happy at 1000rpm idle where I pull 10in. Based on all the good imput (which I really appreciate) I feel ok with the current idle vacuum. After the trans is installed, I am thinking the idle, in gear, shouldn't cause the vacuum to drop too much with the 4000 stall??? If it does I will go to the 4.5 pv's.
Old 10-02-2008, 09:21 AM
Bug,
you do need to re-work the dist due to that cam....
I posted try 18* base because most Chevy dist are 20* or 22* of cent (18*b+22*c=40* TT WOT and that's very likely to much!!!)
your new Hg values are about correct for 18*b and that cam duration....
here's my favorite link for ballparking cam duration versus idle Hg...
click on each graph gives all the motor details for that cam and expected Hg versus idle rpms values when correct for the cam base timing is applied (per the other link article)....
http://www.compcams.com/Technical/DynoSheets/
LOL:
F-bird "likes" mega duration cams on the street (I don't!), I'll leave it to him to write out the dist set up....
ps: if you are going to do much intown/intraffic driving adding a MSD or other multi-spark box is likely a good plan....
Old 10-02-2008, 09:35 AM
6426yy's Avatar
Sounds like a killer combo. What are you putting this thing in that weighs 2200 pounds?
Old 10-02-2008, 10:45 AM
Banned
one very important thing that was not mentioned was compression and ring gap. that alone can make a huge difference! I cannot say enough about Gapless rings for idle quality (though most people use them for power), nor the effects of compression on cam timing. What's your cranking compression? cranking compression is an excellent tool for figuring a good place to set initial timing.
Old 10-02-2008, 11:26 AM
406 bug's Avatar
9.82 @ 139mph
Originally Posted by red65mustang
Bug,
LOL:
Thanks for the Info. I am using MSD distributor and box. The plan is to set it up for a total advance of 36 to 38 Deg.
Old 10-02-2008, 11:57 AM
406 bug's Avatar
9.82 @ 139mph
This motor is in a 1966 vw bug. (406Bug) The shell of the body remains completly original looking from the outside. The chassis is all round tube cromemoly with a full cage. Motor is up front mounted with motor plate. Front susp. is Strange Strut with narrowed Pinto rack. Rear is tubbed with narrowed 9" , four link with coilovers. I will someday post pics.
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 69 03-10-2014 06:10 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 01:51 PM
Idle problem sic72 Engine 2 07-06-2007 11:33 PM
Cam lope question joeford Engine 4 08-10-2006 09:14 AM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 06:39 AM
