vacuum to the transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2011, 03:43 PM
No vacuum to the transmission modulator valve
Old 09-08-2011, 03:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What are you working on ????
Is it hooked up ? you probably have a hole or a pinched line or something like that. unlees it came un-hooked at the trans. When did this happen all at once ?
Cole
Opinions on ported of full vacuum for vacuum advance ? y2k600f4 Engine 13 10-07-2011 09:38 PM
Trouble with automatic transmission ? vacuum 41FordBusinessCoupe Transmission - Rearend 6 04-12-2010 08:51 AM
c-6 transmission vacuum Tryin2MakeIt Engine 2 01-17-2008 04:20 PM
engine vacuum and vacuum secondary carbs poorhighschooler Engine 3 04-30-2003 07:40 PM
ok to use same vacuum line for vacuum advance and tranny vacuum modulator? brian400ex Engine 4 02-19-2003 02:25 PM
