Vacuum trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2002, 06:34 PM
Question Vacuum trouble
Fresh 68/302 w/edlebrock cam--lift/I-448..E-472...Duration/I-204..E-214 prformer manifold....Holley 600...timing at 10 degrees...however..when the c-4 trans tries to shift 2-3...the vacuum drops way down to about 3 or 4 inches and this causes a lag in shifting....and I can't get the idle quite as smooth as it should be...have checked all vacuum ports....readjusted valves/carb....no leaks are apparant...what can I be missing?????
Old 08-08-2002, 06:37 PM
aka Duke of URL
Arrow
Check operation of the modulator valve and the vacuum connection there.
