16Hg is plenty good......
for a street car, 14Hg is about the "practical" minumum to keep the fuel/air mix in suspension (all the way thru the longer intake runners) for a decent idle burn and no fouling (especially with colder ambient air temp) once you have 14Hg+, then it's just minor tweeks of the base timing (1-2*) and carb versus idle rpms to find the setting your combo likes best your "multispark box" helps alot at idle....you may be able to use a lower idle rpm's and only 13Hg and still have good throttle resonse Last edited by red65mustang; 12-25-2007 at 08:57 AM. |
Find the amount of spark timing that gives you the highest idle manifold vacuum with the least amount of throttle opening at the idle rpm you prefer. recurve the distributor to refect the timing required.
Something around 24deg at idle and 32-36deg at max mechanical advance @-/+ 3000rpm is good. |
| Vacuum advance hooked up directly to manifold....is this bad????? | Steve-0321 | Engine | 66 | 08-21-2009 06:37 PM |
| vacuum advance help | batman09 | Engine | 14 | 09-09-2004 09:42 PM |
| at wits end on ford brakes....... | crazy larry | Suspension - Brakes - Steering | 30 | 04-06-2004 05:39 AM |
| Tuning and Timing with a vacuum gauge? | FASTCHEVY | Engine | 6 | 03-21-2004 10:21 AM |
| Vacuum questions | screamin340 | Engine | 1 | 01-26-2004 08:34 PM |
