Valspar single stage - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 12:04 PM
I am new to painting but in the past few months I have sucessfully sprayed 2 cars in bc/cc. Yesterday I painted a truck in single stage. It was valspar 327. I mixed it as instructed and it was like glue. I put in my hvlp gun with a 1.4 tip and it just sputtered out. Then I put it in my siphone feed gun with a 1.6 tip (might be 1.8) that i use for primer and I still had to way over reduce the paint. Is there something worng withj this paint? Is all single stage like this?
Old 09-19-2010, 01:37 PM
How did it say it should be mixed?
Old 09-20-2010, 08:37 AM
It said 8:1 with activator and then may be reduced 10-15 percent. I double checked that on valspars website too.
Old 07-05-2013, 05:28 PM
I've had the same issue, and called Valspar and they thought it was odd, but perhaps the heat that I'm spraying at - around 80 degrees.
How much reducer are you using? I'm using 50%.
Old 07-06-2013, 12:36 PM
It was a while ago now so I'm not really sure. I know I mixed activator it said to and then I think it said reduce up to 10% but I think I had to reduce like 50%. maybe it was a bad batch. I have used valspar single stage since and havent had the same problem.
Single stage vs Two Stage vs 50% base/clear a1960apache Body - Exterior 51 09-19-2010 07:16 AM
Compressor - Single vs. Dual Stage cab Garage - Tools 28 09-06-2010 05:48 PM
Air Compressor for Automotive Painting m1helmethead Garage - Tools 34 12-26-2009 08:36 PM
Valspar Omega Single stage Good? Bad? kustomfab Body - Exterior 6 01-03-2006 07:39 AM
Single stage and duel stage air compressor? DeathByGreaser Body - Exterior 24 10-19-2005 07:33 PM
