valve adj - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2012, 10:59 AM
valve adj
if hydraulic lifters are adj to tight [1 full turn after zero lash] what effects would this have, if any on total timing? thank you skipp 468 bb mild cam
Old 11-22-2012, 12:08 PM
life is a temporary assignment
If they are to tight, they will eat a lobe..I go a 1/4 to half of a turn on mine..
Old 11-22-2012, 01:09 PM
ericnova72's Avatar
More for Less Racer
Adjustment that is still in the range offered by the hydraulic portion of the lifter will have absolutely NO affect on cam timing (I think you are wondering about duration and lift amounts?). Loose...tight... it makes no difference to cam timimg as long as you are still in the hydraulic range of the lifter. You can't change cam duration or lift by changing the adjustment on a hydraulic cam - that is only possible with a solid lifter design.
If the adjustment is too tight and bottoms out the hydraulic piston in the lifter,... then you will have a distinct miss due to valves being held off their seats when they should be closed.
Old 11-22-2012, 03:37 PM
adj lifters
thanks for the help, the reason i was asking was a timing of 50+ degrees is were the car runs right i built the motor the timing marks are on 6+12 o'clock positions , does not start hard,no pinging etc.has me stumped thanks again Skip
Old 11-23-2012, 03:57 AM
bondo's Avatar
Ayuh,.... It sounds like yer confusin' Cam timing with Ignition timin'...
While vaguely related, they're not really dependent on each other...
Old 11-23-2012, 07:07 AM
I appears that you may have the engine 180 degrees out of timing if you are adjusting the valves with #1 at TDC on the compression stroke.
Many shop manuals show to install the timing sprocket marks at 6 o'clock and 12 o'clock on the cam sprocket and crank sprocket but the shop manual neglects to tell you that is #6 cylinder at TDC on the compression stroke. It is easier to align the timing marks in that position but after the timing marks are aligned at 6 o'clock and 12 o'clock, the crank needs to be turned by hand one revolution CW to bring the cam sprocket timing mark from 6 o'clock to 12 o'clock and the crank sprocket timing mark once again to 12 o'clock, if you intend to adjust the valve with #1 cylinder at TDC on the compression stroke.
how difficult should my motor be to rotate after valve adj. jppcrowe Engine 6 06-07-2009 08:10 AM
cam timing&valve adj yragat Engine 1 08-22-2007 10:26 PM
adj. modulater valve runn141 Transmission - Rearend 1 02-04-2007 01:56 PM
Adj Brake Proportioning Valve? sha_ba_do_bang Suspension - Brakes - Steering 7 11-07-2005 01:10 AM
Adj valve quartet Engine 0 11-02-2003 06:40 PM
