valve adjusters bottom out before lash is correct how do u find correct pushrod lengt - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2011, 09:12 AM
country gearhead work for dodge dealerships as diesel tech all my life own 74 pontiac ventura custom with 68 400 ys code engine with 4x heads not first hotrod but favorite
Old 02-03-2011, 10:48 AM
BOBCRMAN@aol.com's Avatar
Cheap and easy way to do a Pontiac. Place thick 3/8 washer (like the ones on old SBC stock exhaust bolts) between the adjuster nut and rocker ball. This gives you 1/8" more adjust.
add; Push rod length determines where the rocker rides on the valve tip. Usually a trial and error event for the novice. Buy an adjustable pushrod checker and have at it. When the rocker travels across the valve tip the least and stays well centered. Measure the pushrod checker and go from there..
Old 02-03-2011, 01:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You will be way ahead of the game if you lose the bottleneck studs and use straight studs and polylocks.
But either way, you have to keep the lifter from collapsing, either by using a solid lifter or converting an old hydraulic lifter to solid. Be sure the seat height of the lifters are the same.
Old 02-03-2011, 03:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, This should be in the engine section.
Cole
how to determine correct pushrod length jarrettandroski Engine 4 11-27-2008 10:02 PM
Correct valve overlap for blown motor? stonebreaker Engine 31 02-22-2007 09:17 PM
Do I have correct pushrod length mouseman Engine 18 09-26-2006 09:27 AM
Correct Valve Height Measurement ezobens Engine 1 03-11-2006 04:04 PM
Where can I find the correct battery cables Rukee Electrical 6 04-21-2003 07:57 PM
