Do you need info on the exact sequence to follow to adjust solid lifter valves (ie how to tell when the lifter is on the base circle of the cam lobe)?
68chevell_ss yes i need to know the procedure for setting the valves and about how often i should do it. i was wondering if there was an easier way than doing one valve at a time. THANK YOU for any info
73luvdrag, I use a book by David Vizard which gives me the sequence so I found a webpage that gives you the same information:
www.centuryperformance.com/valveadjustment.asp I don't know how much you know about valve lash adjustment but this page will give you just about all the info I can tell you without me having to type it all out. The section "Valve Adjustment the Quick Way:" will give you the exact sequence to follow when setting the lash. My only comment is that I don't set the intake valves all at once and then do all the exhaust valves. When you start setting them you will notice that you will alternate between an intake valve and an exhaust valve each 1/4 rotation of the crank. adjust 1int when 6int fully open adjust 3exh when 2exh fully open adjust 8int when 5int fully open adjust 6exh when 1exh fully open adjust 4int when 7int fully open adjust 5exh when 8exh fully open adjust 3int when 2int fully open adjust 7exh when 4exh fully open adjust 6int when 1int fully open adjust 2exh when 3exh fully open adjust 5int when 8int fully open adjust 1exh when 6exh fully open adjust 7int when 4int fully open adjust 8exh when 5exh fully open adjust 2int when 3int fully open adjust 4exh when 7exh fully open Actually there is nothing "Quick" about the "Quick Way" procedure. It takes a little time but that is the cost of running a solid lifter cam and worth it if you do it correctly. Hope this helps! Sorry, forgot to comment on the frequency of adjustment. I run a solid roller in a street/strip car so I don't adjust as often as one would in a drag only car. I adjust mine every other time to the dragstrip but I'm probably on the anal side and I have poly locks. Hopefully someone with a drag car can input on their frequency. And as far as I know you need to adjust one valve at a time in order to make sure you are on the base circle of the cam for that valve. You don't want to skimp on this procedure as the consequences of doing it incorrectly will cost you. Have fun and good luck! Last edited by 68chevelle_ss; 05-15-2004 at 03:01 AM. |
