Valve adjustment opinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 09:36 PM
396chevelle's Avatar
I was just curious as to what you guys think would be the correct preload for my valve adjustment. I have Comp cams .510/.495 hydraulic flat tappet and decided to adjust the valves. I called comp cams and spoke with a tech and was told 3/4 more turn after 0 lash should be good. I then adjusted them to his recommendation. I know 3/4 is probably ok, but I'm so used to going 1/2 turn extra. Should I leave it were it is or go with 1/2 turn? Thanks.
Old 01-27-2012, 07:27 AM
455olds's Avatar
I have always done 3/4 turn but 1/2 should be fine if you are more comfortable with that. As long as you are talking about a Chevy engine.
Old 01-27-2012, 03:28 PM
Yep, it's a chevy. I've got it at 3/4 turn now. I'm just used to doing 1/2 turn. Im sure Ill be good! I just needed some assurance.
BBC Valve Adjustment 31fordcoupe Hotrodding Basics 7 06-12-2011 09:46 PM
350 valve adjustment turbofirebird350 Engine 6 03-18-2011 03:34 AM
valve adjustment niabd Engine 2 11-19-2008 08:46 PM
Valve Adjustment Penumbra General Rodding Tech 12 12-17-2003 08:53 PM
Valve adjustment T-Bucket Engine 5 05-22-2002 09:04 PM
