Valve adjustment question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2013, 07:47 AM
I was wondering if the procedure for adjusting valves is the same with one of these in place.
DSC_0959 (2) | Flickr - Photo Sharing!
I dont know the correct terminology for it, pardon my ignorance. However was wondering if you adjust the valves with this still in place or it needs to be removed?
Thanks in advance.
Old 02-01-2013, 08:07 AM
engineczar's Avatar
Technically it's the same but because of tolerances in stud location the lash changes on some of the valves when you tighten the locking bolts on the stud girdle.
What I do is a rough lash adjustment without the girdle installed or left completely loose. Then with the girdle installed and completely tightened I check the lash at each valve. Some will change at this point either looser or tighter.
Then you have to loosen up the girdle one stud at a time on the ones that are off to make the adjustment. Tighten and re-check lash.
Also when you install the girdle make sure it doesn't sit so low that it contacts the top of the rocker at any point during the cycle.
BSE Racing Engines
Old 02-01-2013, 08:12 AM
That is a Rocker Arm Stud Girdle. You adjust your rocker arms first, then install the stud girdle.
Old 02-01-2013, 11:41 AM
So removing it, set lash, install it and re check lash, then make any adjustments from there.
Old 02-01-2013, 11:51 AM
vinniekq2's Avatar
I check the lash first,then recheck lash after I remove or loosen stud girdle. do some math and some guessing then reinstall/tighten girdle
Old 02-01-2013, 11:27 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Originally Posted by taylor23 View Post
For valve adjustment start with removing valve covers, also remove the spark plugs in order
to turn over engine. Than loose the entire rocker arm adjustment nuts. Now adjust valve
with long handled ratchet.
marine utility pedestals
Whats the Ad for? Did you post that?
Jester
Old 02-01-2013, 11:35 PM
vinniekq2's Avatar
isnt "M-tech" a scam?
Old 02-01-2013, 11:50 PM
I clicked on it and couldn't get out He has it on other posts too so he's doing it!!!!!
Look at his post its stupid!!! Just something to type!!!
http://www.hotrodders.com/forum/atta...1&d=1359788103
Jester
Old 02-02-2013, 12:22 AM
Thanks : McGruff and Deputy Dog That guys gone!!!!!!
Jester
The Following User Says Thank You to painted jester For This Useful Post:
vinniekq2 (02-02-2013)
Valve adjustment TDoylecinci Hotrodding Basics 7 10-19-2012 04:53 PM
valve adjustment question 4thgencamaro383 Hotrodding Basics 4 09-21-2011 10:22 AM
400 Pontiac Valve Adjustment Question?? budthespud Engine 11 04-13-2009 05:01 AM
Valve adjustment question HammerGVette Engine 3 04-04-2008 07:07 PM
440 valve adjustment question STATUTORY GRAPE Engine 4 03-08-2008 02:21 PM
