valve adjustment sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2010, 01:06 PM
The intake is off,new build,can i just adjust each valve by looking and making sure the lifter is all the way down ?
Old 11-12-2010, 01:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sure can. I always include the following, it may help if you need to adjust the valves after buttoning everything back up:
Firing Order: 1-8-4-3-6-5-7-2
Distributor rotates CW.
Remember the valves go: E I I E E I I E
Adjusting Hydraulic Lifters for Proper Preload
EO/IC Method (Exhaust Opening/Intake Closing)
In order to adjust the preload, the lifter must be properly located on the base circle or "Heel" of the lobe.
At this position the valve is closed and there is no lift taking place. You will need to watch the movement of the valves to determine which lifter is properly positioned for adjusting.
1. Remove the valve covers, and pick a cylinder that you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder's intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. (If you are uncertain that you are feeling the "Zero" setting, jiggling the push rod up and down will sometimes give a better sense of when all the clearance has been removed.) When you feel a slight resistance to the turning of the pushrod, you are at "Zero Lash". Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close.When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again. It's a good idea to make a note of what cylinders are adjusted, as you adjust them.
The exact amount of preload to use varies among builders and cam/lifter manufacturers. If in doubt, use the recommended amount of preload.
Old 11-12-2010, 03:09 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
http://www.youtube.com/watch?v=89o5rLpbCgI
Builder says 1/4 more on rockers....HHHMMM? sooper Engine 29 07-16-2010 01:17 PM
David Vizard's Idea of Almost Bottoming Hyd. ? BUFFALOBILLPATRICK Engine 46 06-24-2010 02:25 PM
sbc hydraulic valve adjustment hottrodz Engine 10 12-16-2006 10:46 PM
sbc 355....no oil pressure to valve train. bigbadbowtie Engine 26 01-27-2006 07:31 AM
Valve lash adjustment, Now I'm confused? Jag Daddy Engine 5 04-15-2004 11:27 PM
