Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve adjustment sequence
Old 10-09-2010, 08:24 AM
Caballerokid's Avatar
Caballerokid Caballerokid is offline
Originally Posted by pepi
Thats good for someone that does this regularly, but I would caution that doing it this way you will need to pay close attention to where you are at, a pro or seasoned mech. no problem, rookie stick with one cylinder at a time. Buzzing all over the engine could lead to a costly little mistake.
I mean really just how much time ya looking to save here ?
I'm a fully certified tech, this is just the first custom motor I've built and I have heard that doing the valves in this method is more acurate and will prove more hp than setting the valve on tdc for each cylinder. was i misinformed?
