Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve adjustment sequence
Old 10-09-2010, 08:52 AM
pepi's Avatar
pepi pepi is offline
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I am not a ''certified tech'' just someone that been messing around with hot rods for a few years.
If you think this procedure is for you and you are paying attention to what you are doing fine. Dyno it before and after show us the out put data of your gained HP, I would be interested in the results.
I was pointing out that the method was a good one might not be for a rookie, or only a few times a year guy that adjust his own lifters.
You are the one that said " I haven't done this in such a long time." I mean who knew a real certified tech wow.
I here loads speed secrets and tricks and what you here is not always fact.
