Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve adjustment sequence
Old 10-09-2010, 09:54 PM
mud.man.rj's Avatar
mud.man.rj mud.man.rj is offline
valve adjustment.
I started out about 30 years ago adjusting 1/2 the int and 1/2 the exh valves but not all are perfectly at 0 lash this way so some are a bit tight and some a bit loose. So that is where the extra 6hp comes from when each valve is adjusted separetly. When I started adjusting them separetly I could pretty much put the covers on when done and not need any further adjustments.
