Valve angles - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 05:13 PM
Valve angles
between a cylinder head with say 9 degree valves and one with angles nearing 20 degrees what is the major advantage? shrouding only?
Old 10-17-2012, 05:41 PM
How fast is fast enough?
A straighter path to fill the cylinder- more effective use of the valve.
One drawback is longer valves, taller, heads and intake, space requirements.
Old 10-17-2012, 06:58 PM
With more angle do you ever.loose piston to valve clearance
Old 10-17-2012, 07:13 PM
you can, depends on the head and piston.
Valve angles- confused Jeff The Ruler Engine 2 08-16-2009 06:10 AM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 2 12-26-2006 01:12 PM
Pinion angles... Canzus Suspension - Brakes - Steering 5 01-05-2005 06:07 PM
driveshaft angles, what about horizontal angles catscan4free Transmission - Rearend 4 01-26-2004 06:23 PM
