Valve body adjustments - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2003, 12:41 PM
Post Valve body adjustments
I have a TH350 in a 4x4. I heard you shouldn't go too radical on the shift kit cause it will break the roller clutch. I've been told I can plug one hole, drill one hole and remove three check balls and that is the same as a Shift Improver Kit for Towing and Hauling. Does anyone have the specifics on this manuver? (Maybe the instructions from a tow/haul package). Thanks for the help.
