Valve Body Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 10:16 PM
Valve Body Question
Hello All, It has been about 12 years since I worked on A TH 350 Auto trans I was givin a transmission and decided to do an " Fluid Filter" I discovered that the "s" hook in the valve body of my 1978 TH 350 had "Poped" off i have allready dicovered the reason this happened and repaired it but my Question is while looking at a TH 350 vavle body facing up there is a Spool or shifter valve ( I may be using the wrong term) that attaches with an "s" hook to linkage looking at the Spool do the grooves face Up or down? I hope i explained this question correctly THANKS.
Old 09-16-2007, 08:45 AM
Overdriv's Avatar
It's been a long time since I've done a 350, but I don't remember it making any difference.
I'm sure someone will correct me here if that is not the case.
Old 09-16-2007, 12:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am not sure what grooves you speak of.
the S hook will only install correctly one way , so the linkage operates the manual valve in the v-body.
Old 09-16-2007, 06:47 PM
TH 350 valve body
THANKS for your replys I finally reached my local 350 "expert" and everything is back together and working great.
Old 09-16-2007, 07:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
kool
proportioning valve question ScottRods2945 Suspension - Brakes - Steering 1 07-01-2007 05:52 PM
A Body mini tub question wally8 Suspension - Brakes - Steering 1 08-11-2004 05:09 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
200-R-4 VALVE BODY ASSEMBLY GRANDNATIONAL6 Transmission - Rearend 2 05-08-2003 03:22 AM
C4 valve body mhaener Transmission - Rearend 0 12-26-2002 11:01 AM
