Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve clearance
Thread: Valve clearance
Old 07-26-2012, 06:54 PM
prostcelica prostcelica is offline
Valve clearance
I have a stock SBC 350 bottom end. I am going to be putting some aluminum heads, roller cam, intake etc.
My question is how much valve lift can I get away with before running into valve to piston issues??
Stock flat tops with with 4 eyebrow valve relief, .025 deck heigth, .015 head gasket.
I heard you can run into issues with the eyebrows being to small to accomodate 2.02 valves??
Any input would be great. Thanks in advance.
PS: cam I wont to use has following .54 / exh .562
