Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve clearance
Thread: Valve clearance
Old 07-26-2012, 10:05 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Do you hav another similar cam to mock up with?
Similar duration @.050" and LSA. The lift has little to do with VTP clearance
as the piston is way down the bore when the valves are at full lift.
The duration and overlap has more to do with it.
valve opening at near TDC.
You don't give any info on the heads Non stock valve location etc.
