Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve clearance
Thread: Valve clearance
Old 07-27-2012, 04:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by prostcelica View Post
I have a stock SBC 350 bottom end. I am going to be putting some aluminum heads, roller cam, intake etc.
My question is how much valve lift can I get away with before running into valve to piston issues??
Stock flat tops with with 4 eyebrow valve relief, .025 deck heigth, .015 head gasket.
I heard you can run into issues with the eyebrows being to small to accomodate 2.02 valves??
Any input would be great. Thanks in advance.
PS: cam I wont to use has following lift......int .54 / exh .562
Besides the raw lift, the cam timing and additional advance/retard has an effect as well. There are so many variables that it is hard to guarantee anything when it comes to valve to piston clearance. I would definitely mock this up first and check the p to v.
Here is a page on things to check.
Stock piston valve reliefs need to be checked and clearanced if needed w/2.02" intakes. Aftermarket pistons tend to have more generous reliefs.
