Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Valve clearance
Thread: Valve clearance
Old 07-28-2012, 01:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by prostcelica View Post
Thanks F-bird
Thats great info. That is a good plan. Is it super critical to use a solid lifter for mock up?? I guess I can probaly just buy a couple of solids instead of a hole set. Also what is minimum VTP clearance?
Is there a cam manufacture in particular that sells a "street" solid roller and lifters??
You can buy single lifters. I have used a hydraulic lifter and taken it apart and filled it up w/small washers to make it solid. Either way, just so the lifter cannot collapse. You can reuse it when you check/set the geometry.
0.080" on the intake and 0.100" on the exhaust is considered by many to be a good safe clearance. You will probably find the closest near-miss at the exhaust valve on overlap, when the piston is chasing the exhaust valve back onto its seat.
