Valve clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2012, 06:54 PM
Valve clearance
I have a stock SBC 350 bottom end. I am going to be putting some aluminum heads, roller cam, intake etc.
My question is how much valve lift can I get away with before running into valve to piston issues??
Stock flat tops with with 4 eyebrow valve relief, .025 deck heigth, .015 head gasket.
I heard you can run into issues with the eyebrows being to small to accomodate 2.02 valves??
Any input would be great. Thanks in advance.
PS: cam I wont to use has following lift......int .54 / exh .562
Old 07-26-2012, 07:58 PM
vinniekq2's Avatar
That cam though not high lift,likely wont fit.depends also on duration and lobe angle.always check clearances
Old 07-26-2012, 08:16 PM
DoubleVision's Avatar
There's no way to know and nobody can tell you rather or not your going to have clearance issues you have to check it and there's no way around it.
A cheap method we use is play dough with talcum powder to prevent the valve from sticking.
Old 07-26-2012, 09:39 PM
Hmmmm. I was planning on checking clearances but I'm worried about buying a $300 cam and not being able to use it.
Old 07-26-2012, 11:01 PM
I'm going to use either AFR 180 street or patriot freedom series 185. I was hoping to use a comp XE288 or XE 294 hydraulic roller. I would attach the link on the cams but I'm posting from my phone so I hope that helps. The only cam I have is a flat tappet magum 270. its 224 at .50
Old 07-27-2012, 01:29 AM
safer is better
when i doubt go to a place like howards cams or elgin or something and buy a cheap solid cam with close to the same numbers...may be impossible when comparing to a roller but its worth a try. most solid lifter stuff is 90 bucks from them. Or as an alternative. check with some local dirt track guys and see if they have a comparable one laying around you could use to test. Us dirt guys never get rid of anything.
Old 07-27-2012, 04:32 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Besides the raw lift, the cam timing and additional advance/retard has an effect as well. There are so many variables that it is hard to guarantee anything when it comes to valve to piston clearance. I would definitely mock this up first and check the p to v.
Here is a page on things to check.
Stock piston valve reliefs need to be checked and clearanced if needed w/2.02" intakes. Aftermarket pistons tend to have more generous reliefs.
Old 07-27-2012, 06:44 AM
Agreed, can't really tell anything without mocking it up. Too many variables.
However, it's not THAT big a "deal" to have the valve reliefs "fly-cut" (type of cutter used for the operation). Any automotive machine shop that has a "piston vise" and a mill can do it. This is the procedure to be used when cams and pistons not "stock" are used. Common practice.
Jim
Old 07-27-2012, 08:26 PM
That seems like a lot of cam for a stock bottom end.
Old 07-28-2012, 01:40 AM
Thanks F-bird
Thats great info. That is a good plan. Is it super critical to use a solid lifter for mock up?? I guess I can probaly just buy a couple of solids instead of a hole set. Also what is minimum VTP clearance?
Is there a cam manufacture in particular that sells a "street" solid roller and lifters??
Old 07-28-2012, 01:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks F-bird
You can buy single lifters. I have used a hydraulic lifter and taken it apart and filled it up w/small washers to make it solid. Either way, just so the lifter cannot collapse. You can reuse it when you check/set the geometry.
0.080" on the intake and 0.100" on the exhaust is considered by many to be a good safe clearance. You will probably find the closest near-miss at the exhaust valve on overlap, when the piston is chasing the exhaust valve back onto its seat.
Valve to piston clearance Dean Harrington Engine 3 01-25-2012 12:10 PM
valve to piston clearance hi railer Hotrodding Basics 5 01-18-2012 07:01 PM
valve clearance tularider Engine 0 02-26-2009 02:24 PM
How much valve clearance is good? Farmer Buck Engine 18 04-11-2008 10:51 AM
Please help with Valve Clearance 1967stang Engine 2 01-11-2004 06:58 AM
