-   -   valve clearance question (http://www.hotrodders.com/forum/valve-clearance-question-35279.html)
79 Malibu327 03-02-2004 10:16 PM
whats up guys do you think it is imperative that i check the valve clearance on this setup? comp cams 292 adv dur cam .501/.501 lift, 64 cc chamber heads, 10:1 flat tops with two valve reliefs and .025 deck height?
lluciano77 03-03-2004 01:11 AM
I don't know what pistons you are running, but I don't think there are too many flat top pistons out there that you would have to worry about clearances with only .500" lift. You could clay the pistons to be safe.
